When framing with my Roly diode laser, is there a way to make the framing make more than 1 trip around the parameter without going back to the pc? Thank you.
Lightburn versions prior to 1.5 frame once per command. 1.5 now has the option to frame continuously. I do not yet have the newer version so I’m unsure how to enable the new feature.
Edit, Device Settings, left side about 1/3 down, Frame Continuously.
A little window will pop up saying hit OK when done.
Thanks for reminding me that was added!
