Framing with Laser on with Atomstack 130w diode
Hi I’ve enabled the fire button as well as laser on whilst framing but everytime I try to frame with the laser on it only frames the area. How do I get my laser to fire up whilst framing. I’ve turned the 'Move@ tab with Power setting upto 4%. I started at 0.25 and worked up, but still nothing happening? Any help really appreciated.
Did you enable this in the Device Settings?
Yes
In the console, if you type $$ and press enter, is the value $30 set to 255?
This is what you’ve told LightBurn to use:
So if $30 is 1000 (which is most common these days) then that value in Device Settings is incorrect.
