Framing with the laser on
Hi … been awhile sense I’ve been here … I am useing lightburn software with ortur laser master 2 … when I first started useing it I could fire the laser on low power and frame my project with the light on …now when I go to frame my project the laser turns off … i don’t know how to change the setting so the laser stays on … thank you
I am in on this…my yora did this as well…used to frame with laser on now it shuts off.
Don’t hold me to this but seems like when I was using Lightburn with my Ortur LM2, you had to hold down the shift key, or something like that, for the laser to stay on while framing.
On of the other duod laser users might be able to verify or correct this.
I think it should be more transparent than holding down shift … I have been looking for this feature!! (I havent tested that holding shift works yet… but will definitely try it).
you need to press shift key before hitting frame, once you’ve done you can release the shift, beam laser will stay on for all the frame :wink:
well that was it guys thanks. Don’t remember having to do that but I don’t trust my memory sometimes anyway.
