Hello,
let me introduce my new Single Line font with on-line SVG generator :
Project is experimental, so I am curious about any opinion or suggestion (especially when engraving
Hello,
Thatās a great start to a resource that can really be useful.
As youāre building the tool, maybe some inspiration on other Single Line font types having⦠more than one line (which have their own weird uses):
But on your last inquiry regarding engraving, I find that single line fonts are not your traditional candidates for āengravingā (if weāre talking raster engraving). But for line mode / vector engraving, thatās where they shine! See on the right side, a traditional scan / engrave layer makes for strange result (but on the left, line layer is just what these fonts are great for):
Do you only have the one font? Or is there a way to change to font?
Iām working on some other fonts, like a funky script above or 2-layers (line + fill) font:
⦠" Or is there a way to change to font?"
From my point of view, I can relatively easy prepare TTF font in new SVGinOpenType format. But this has one drawback: at this moment only Adobe Illustrator support it (not Inkscape or LightBurn)
We actually have support for single line SHX fonts coming in LightBurn as well. Itās getting close to being given to the beta group.
SHX is equal to SVGinOpenType?
No, as far as I know no, SHX is poorer
first of all SVGinOpenType format uses OpenType features like Ligatures, Kerning, Contextual Alternates, Stylistic Sets etc.
Depends on how you look at it. The fact that SHX is much, much older than OpenType SVG is an advantage in many ways. Specifically the fact that SHX is designed for CAD/CNC applications and has been around long enough for there for be many SHX fonts available.
Yes, itās an old (and kind of ugly) format - but LightBurn users wonāt need to worry about any of that as weāre handling all the format parsing for you. And OpenType SVG is still designed for display - not for CNC applications. Font glyphs could still have features that are not really possible to ārenderā with a laser as opposed to SHX which is designed for exactly that scenario.
Thatās not to say, at all, that what youāve made @glukfonts isnāt cool. It very much is and I plan to use it - especially once you have more fonts. Just trying to explain the difference and reasoning with SHX - also weāve had many people just specifically request SHX support and itās a feature that RDWorks has that we didnāt yet.
@adammhaile - I agree. I donāt expect, LightBurn will support SVGOpenType fonts. Just @vedafilter asked about differences beetwen formats. As far as I know, there arenāt yet SVGOpenType fonts for cnc.
That was one of the reasons why I created my own on-line renderer
Thanks for your explanations.
I have downloaded now some SHX fonts (preparation for the Beta test
). How do install them on PC?
And how can I print a sample book of them?
Totally get it and was just trying to explain the difference in terms of LightBurn usage ![]()
Just stick them in a folder and then in LightBurn you will tell it what folder to check in the Settings dialog. Thereās no āinstallingā them on the operating system.
Only way to get a sample right now would be to just manually do it in LightBurn - though Iāll talk to @LightBurn about integrating a way to show samples of your SHX fonts. We talked about having them render like TTF fonts in the font chooser but for a bunch of technically reasons that wasnāt really possible.
@adammhaile - nice, then let me introduce (still work in progress)
two layers font:
1- true single outline for ālineā LightBurn layer
2- āfillingsā for āfillā layer
in LightBurn after SVG import it should look so
with 2 separate layers ( LightBurn set automaticaly mode āfillā and ālineā - I have no Idea, itās lucky, or detect it from open contours ?)
What are the āfillingsā? Is it separate lines it just a filled shape?
You probably had that red cut layer as a fill previously.
What is the purpose of that font? We can already choose in LB layers the option line+fill. Or is something special hidden in the word ātrueā?
@RalphU thank You for info. I corrected temporarily, and PDF should work (at least in LightBurn) but result is unexpected and requires more investigation ā¦
Are you going to make this font available offline / able to download?
@Rick normal fonts EtharnigSc & EtharnigNo12 (on which EtharnigSL is based) are available for download:
www.glukfonts.pl/font.php?font=EtharnigSc
Singleline EtharnigSL for now is available only on-line
