Is there any way to draw lines freehand around irregularly shaped objects? Been trying but haven’t found a way to do that yet.
Freehand like with a paintbrush? No. The closest thing would be using the Draw Lines tool which gets you both straight lines and bezier curves.
Actually found the answer in another forum. The way I wanted it, all I had to do was click on the object and then hit the “Offset Shapes” tool (Alt-O). That took care of it.
Ah… very different situation in that case. Glad you got a working solution.
