So I’ve noticed that when using current position along with Cut selected Graphics it’s not what I expect.
If it’s the only graphic it works fine.
What would you like for the outcome to be? That may help someone to lead you to the right answer if you describe what you’re wanting to do. I use that feature often.
You probably want ‘Use Selection Origin’: https://lightburnsoftware.github.io/NewDocs/LaserWindow.html#cut-selected-graphics
