FSL 5th Gen upgrade with K40+ Lightburn compatible
To all you laser Gurus out there, im from a Thunder laser background but have recently got a 5th Gen FSL running Stellaris & Retina engrave which is terrible.
just started an upgrade to fit a K40+ from Omtech as Cohesion3D never have stock of boards.
My issue is the signals from this K40+board to the Laser PSU, I can’t seem to locate them on the K40+ board, has anyone done this?
Laser enable and power level control specifically as I had these on the previous FSL board.
Welcome to the site… We are here to help you … There are lots of different machines, control boards and lps types out there…
It’s always a good idea to give us the best information you have…
A link to
  1. FSL 5th Generation laser
  2. OMTech control board
  3. lps, what kind
We have to find these, then guess if they are the same as yours.
Assume this is some kind of software?
The more you help us, the more we can help you…
Most of these boards are plug and pray, so I’m wondering what exactly is the issue… I understand in a high level your issue, but I’m not following why this is an issue…
What is different that it doesn’t it just plug directly into the machine?
