Full Spectrum Laser Mopa Conversion
Hey guys I want to switch over my Full Spectrum Laser 60w Mopa to be able to use lightburn. I know I need to change the board and do some wiring. I haven’t found any information on doing it for the mopa if someone can point me in the right direction I would greatly appreciate it.
I joined the Full Spectrum Forum because I wanted to take a look at a diagram for a Ruida controller conversion.
https://fullspectrumforum.com/
The admin team states pretty clearly that they don’t work for FSL.
This is on swapping an EZCad3 into an EZCad2, making it Lightburn compatible… Maybe it will give you some clues.
This is about the best I’ve seen… have no clue about how it’s connected, but it has to be similar if it’s a compatible source.
Good luck
@JohnJohn - went to the site and their co2 Ruida conversion wired the flow sensor to the lps instead of the Ruida… I guess I question that…
