Wondering what may of happened, one day I was cutting beautiful crisp lines and cuts, then now I’m getting fuzzy lines and laser does not cut… I tried to clean the lens several times, not sure what is going on. I have the XTool D Pro.
It has to be focus/lens or laser… Double check the optics for clean and do a ramp test to ensure it’s focused…
Thank you for your reply,
I don’t see those options in the program.
What options?
It’s machine maintenance…
https://lahobbyguy.com/bb/viewtopic.php?t=428
On mine you unscrew the lens and it will come out, don’t know about yours…
So I was able to unscrew it out pretty easy, I didn’t think it would be, so I totally cleaned it and it seems there are some etchings in the center of the lens. Is this normal?
If it’s etched, that a problem. If it’s residue, I get that when I don’t run enough air pressure.
If you can get it off and clean, no problem…
I did take a picture of it but still figuring this out. I’ll post one as soon as I do.
