G code motion target exceeds machine travel (machine is Jinsuko LC-40
I have been having issues with my laser connecting. I got that fiqured out today but had reset my lightburn in the process. I was going to run my laser grid. When running the outside lines I got the alarm"G code motion target exceeds machine travel. I am using absolute coordinance.
These are my screenshots of lightburn during this job, my settings, and the device settings
Check the firmware (machine) settings. The limits that are set there are taken into account. Not the values you set in LightBurn (device settings). The latter are only for your preference, but the laser ignores them.
Additionally, make sure your laser position is 0,0 after homing, and the workspace size in the firmware is taking the homing-pulloff setting into account. (if the max distance is 400 mm, and you have a pull-off of 2 mm, the maximum usable area is 398 mm).
Before I had my other problem I engraved this grid many times.
I got it, I typed in $$ on the console and saw that $131 was set for 385.000 so I changed it to 395.000 and it is working. Thank you for your assistance.
Brenda
