G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the 'Devices' button to reset the connection)
Waiting for connection…
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S1]
[OLF: 172]
[DATE:14:51:29 - Sep 2 2021]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,35,1024,3]
Target buffer size found
ok
Homing
ok
$RST=*
[MSG:Restoring defaults]
ok
Ortur Laser Master 2 Pro S1 Ready!
OLF 172.
[MSG: Flame detector active,Ambient infrared value:0]
Grbl 1.1f [’$’ for help]
$RST=*
ok
OLF 172.
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
[MSG:Reset to continue]
ok
OLF 172.
[MSG:’$H’|’$X’ to unlock]
no luck. Not sure what or why this ortur is not working with lightburn.
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G59.1:0.000,0.000,0.000]
[G59.2:0.000,0.000,0.000]
[G59.3:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G59.6:0.000,0.000,0.000]
[G92:180.000,243.964,0.000]
[HOME:0.000,0.000,0.000:0]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
It seems to work well on lasergrbl. I would have preferred to use lightburn but at least I did not waste $$ on the software.
This is your offset
Type G92 x0 Y0
in console
Then type $RST=* again
Whats odd is the reset command SHOULD clear your offsets all toguether
Not exactly sure why it isnt
Confirm with $# once done
Can you post a image of your edit → Device settings
