G-code motion target exceeds machine travel. Machine position safely retained
Everything was going fine, did a few coasters. Then this happened, not sure what to do?? Please help
Waiting for connection…
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S2]
[OLF: 185]
[OLH: OLM_ESP_PRO_V1.2]
[OLM: GENERAL]
[DATE:22:44:33 - Oct 25 2021]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMSL,35,4096,3]
Target buffer size found
ok
Homing
ok
ok
ok
ok
ok
ok
<Idle|MPos:-397.000,-397.000,0.000|Bf:35,4096|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:0,0|VA:23614,7|WCO:0.000,0.000,0.000|A:S|H:0>
ok
[GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F100 S0.]
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
[MSG:Reset to continue]
ok
Ortur Laser Master 2 Pro S2 Ready!
OLF:OLF 185.
OLH:OLM_ESP_PRO_V1.2.
OLM: GENERAL.
[MSG: Flame detector active,Ambient infrared value:0]
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
<Idle|MPos:-397.000,-397.000,0.000|Bf:35,4096|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:0,0|VA:23642,0|Ov:100,100,100|A:S>
ok
[GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.]
Starting stream
ALARM:2
On or near line 2:
ok
OLF:OLF 185.
OLM: GENERAL.
ok
Project loaded in 4 milliseconds
<Idle|MPos:-397.000,-397.000,0.000|Bf:35,4096|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:0,0|VA:23628,0|Ov:100,100,100|A:S>
ok
Starting stream
ALARM:2
On or near line 2:
ok
OLF:OLF 185.
OLM: GENERAL.
ok
Not sure what’s going on but there seem to be a ton of Ortur devices ending up with negative coordinates.
Can you run this in Console and return results please:
$0=5.0
$1=100
$2=0
$3=6
$4=7
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=6
$15=0
$16=1
$17=4
$18=0
$19=0
$20=1
$21=1
$22=1
$23=3
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=0
$41=0
$42=1
$43=1
$44=3
$45=4
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$100=80.000
$101=80.000
$102=2124.000
$110=10200.000
$111=10200.000
$112=600.000
$120=2200.000
$121=1800.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$259=0
$260=70
$261=70
$262=320
$263=30
$264=0
$265=50
$266=100
$267=0
$268=0
$269=0
ok
s#
error:2
Numeric value format is not valid or missing an expected value.
<Idle|MPos:-397.000,-397.000,0.000|Bf:35,4096|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:0,0|VA:23628,0|WCO:0.000,0.000,0.000|A:S>
ok
Can you rerun $#? It didn’t take.
s#
error:2
This is all i get ;(
You are typing s#. I’m looking for $#.
That’s a dollar sign. Use cut/paste to avoid confusion.
My bad, here it all is
$0=5.0
$1=100
$2=0
$3=6
$4=7
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=6
$15=0
$16=1
$17=4
$18=0
$19=0
$20=1
$21=1
$22=1
$23=3
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=0
$41=0
$42=1
$43=1
$44=3
$45=4
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$100=80.000
$101=80.000
$102=2124.000
$110=10200.000
$111=10200.000
$112=600.000
$120=2200.000
$121=1800.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$259=0
$260=70
$261=70
$262=320
$263=30
$264=0
$265=50
$266=100
$267=0
$268=0
$269=0
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G59.1:0.000,0.000,0.000]
[G59.2:0.000,0.000,0.000]
[G59.3:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G59.6:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[HOME:0.000,0.000,0.000:0]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
<Idle|MPos:-361.825,-259.912,0.000|Bf:35,4096|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:0,0|VA:23600,0|Ov:100,100,100|A:S>
ok
I’m not sure what’s going on. You’re showing negative coordinates but I don’t see any offset configured.
Questions. Please answer each specifically:
  1. Is your machine homing normally?
  2. Is this an unmodified Ortur Laser Master 2 Pro S2?
  3. Was this ever working correctly? If so, what’s changed between then and now?
Yes it is homing normal. Yes it’s unmodified Ortur Laser Master 2 Pro S2.
Yes it was working fine earlier. I just got it today. Not sure what has changed??
Try a full reset. Run this in Console:
$RST=*
Please copy/paste that. Rehome and then rerun this in Console:
$RST=*
[MSG:Restoring defaults]
ok
OLF:OLF 185.
OLM: GENERAL.
Grbl 1.1f [‘$’ for help]
$RST=*
ok
OLF:OLF 185.
OLM: GENERAL.
<Idle|MPos:-397.000,-397.000,0.000|Bf:35,4095|FS:0,0|Pn:PY|CL:0,100|PS:2,1|ER:0,0|VA:23604,0|Ov:100,100,100|A:S>
ok
Let’s try one thing. Don’t know if it will work.
  1. Run a homing operation
  2. Issue G92 X0 Y0 in Console
  3. Run another homing operation
  4. Issue ? in Console and return results please
