G-code output to memory card - XTool D1 won't read. File type?
Hello all, new user with an Xtool D1 laser using Lightburn software. I’m able to run the laser just fine while tethered to my laptop, however I am having no luck running the laser while disconnected from the laptop using g-code generated by Lightburn saved to the provided transflash card.
What is the required file type for the D1 laser to read? I can’t seem to find this answer anywhere.
The laser is only about 2 months old, the firmware is up to date.
I am using the trial version of Lightburn so far, I wouldn’t think that would matter as the software is saving out a file to the memory card.
Anyone out there getting this to work? Thanks in advance!
i don’t know your laser machine, but LB generate a gcode with .nc as extention, try to change .nc in .gcode
Thanks for the reply, but still no luck.
I don’t know your machine, but these devices usually will not read anything that is not formatted in FAT32, nor SD cards bigger than 32Gb. I would ty with a small SD formatted in FAT32…
Thanks Pablo. The memory card id FAT32 formatted and has 3.7 GB of space.
This is the laser I’m using:
Link
Can you confirm that this use case is even a supported use case? I got the impression that the TF card was meant to be used more as a buffer than as a means of running independent jobs.
There’s no display for this laser, correct? Of so, is the idea that it should just automatically start burning after being turned on?
Here’s what it says on their website:
yup… but me neither was able to find infos on what kind of file type is read by xtool
Weird. Xtool support has yet to reply either, I contacted them directly.
that’s exactly what i will suggets you, contact their support :wink:
Try this. Run a normal job. Then examine the contents of the card. I assume there will be a temporary file stored there. Rename a custom g-code file to the temporary name.
It’s not clear how the job would be run, however. I suspect some sort of sequence with the power button or something similar.
Odd how this capability seems to be completely undocumented.
