Galvo 200w 2.5D lens correction (bulge) 200 x 200mm
Having issues getting rid of bulge. I’ve tried correcting the setting itself but it will not correct or move at all. I’ve tried increasing and decreasing and the bulge stays the same. I made a box at 190x190mm.The middle of the box on the x axis is 194 and the ends are 185, x bulges outward away from the middle. The y axis is the same except it bulge inward toward the middle. isAnyone have an idea on how I could adjust this?
Have you tried the calibrate galvo lens under the laser tools tab?
Yes. I’ve done that a few times. Also corrected actual size.
Only other thing I can think of is the focus is off during calibration.
