Galvo Add-on License Needed for Xtool F1
Does anyone know if I need to purchase a Galvo Fiber Laser add-on to my existing account to support the new XTool F1 laser? I already have a license key for my diode laser and add-on for the Co2 lasers.
Thanks!
It appears to be a galvo, but I don’t know how it’s controller or if Lightburn will connect and control it.
Maybe @berainlb knows if this is a supported device…
Supposedly this laser is supported by LightBurn although I’ve not seen anything definitive about how that’s done. It’s not clear to me if this requires the galvo license or if this somehow works as a g-code device.
I believe the machine is a GCode controlled Galvo - so it will lack some features for proper digitally-controlled galvos.
Plug it in and try it… if it’s grbl based, it should work… You have a licensed copy of Lightburn for your grbl and probably your co2.
It’s sold as Lightburn compatible. I don’t think it’s big enough to be a fiber… it’s a combo of a 455nm 10W and a 1064nm 2W
Good luck
Just plug and play. But you need to follow this instruction!
Why do so many people answer even though they have no idea how to solve the problem, it’s like everywhere else, it’s tedious to read through forums until you find the solution
The F1 is recognized as GRBL and communicates via Gcode on TCP. That’s nice, but I’d like to use the repeat marking functions, which are however not visible for the F1. Is there a way to use Repeat Marking with the F1?
