Hi,
Is there a way to setup something like the auto-rotate feature of EZ Cad 2? I mean on each engraving count, the engraving angle is rotated by x degrees. so for example if the angle is set to 10 degrees, on continuous engravings, the first engraving count is at 0 deg, second time around its 10 deg, third 20 deg. Have I missed something?
For what I can see, in light burn you can select 1 alternate angle and on continue, it switches between original and that angle back and forth.
Hi, On my setup, this option just toggles back and forth. As described above, if I set this to 10 degrees and start engraving on continuous mode, light burn will alternate between 0 deg and 10 degrees. What EZCAD2 does, and what I’m looking for, is for the laser to spin the cut angle by 10 deg on every pass 0,10,20,30,40, etc…
While I haven’t used this option in LightBurn at this point, it’s supposed to operate how EZCad does. I think your best option is to e-mail LightBurn support support@lightburnsoftware.com with a bug report on that. They can offer advice and get it up to the developers to fix if it’s in fact operating incorrectly.
