Galvo Calibration Difficulties
Hello again!
In a separate post I noted that I had to reinstall my laser to LB. As part of this I am calibrating the lens. The LB calibration square shows inward bulge on the Y axis and outward bulge on the Z axis. I finished the calibration (which is off by two mm, presumably because I don’t have accurate measurements for the lines) and went into the menu to set this and all options for taper, skew, and trapezoid are grayed out. Any ideas why this is happening?
I think if taper, skew, and trapezoid is grayed out, that means a COR file is taking it’s place. If you press ‘clear’ you can then edit those settings. If that doesn’t work, a screenshot of your settings would be helpful.
Are you following the instructions for calibrating your lens in our video?
