I am trying to calibrate my camera for my fiber galvo laser, the only issue is the size of the default calibration being 200mm. The majority of users lenses are around 100mm to 150mm lenses, and I have a 150mm and 50mm. Has anyone found ways around this?
The lens calibration dot pattern can be downsized before printing, or you can perform the lens calibration outside of your workspace (this is often easier).
Or are you referring to the size of the target marker engraving? You can downscale its size to fit into your workspace.
