Bounds and hull framing work correctly, but contour doesn’t show anything at all. There’s a different noise coming from in the laser head when contour is selected compared to bounds or hull. If I quickly select and deselect image bounds or outside shapes brief red laser lines show up but not in any kind of image. OMtech 100w MOPA
In your Device Settings (‘Edit’ > ‘Device Settings’), try toggling off ‘Enable Blanking Delay’. It’s under your IO port settings and the ‘Red Dot Always On’ switch.
Worked perfect. Thank you!
