Galvo Driver Swap
I read the galvo installation and I understand how to remove the Lightburn Galvo driver.
Is there an easy way to switch back and forth between EZCad and Lightburn? If not is there a option to just install the Lightburn galvo driver without installing lightburn each time?
Thanks !
I found the driver install. It was in C:\Program Files\LightBurn\EzCad2Driver\dpinst-x64.exe
Thanks
You can use the Zadig Driver swap utility as outlined in the install docs:
https://lightburnsoftware.github.io/NewDocs/galvo/Installation.html#restoring-the-driver
