I’ve been using lightburn for years with my CO2 Ruida lasers but now i’ve just paid for the Galvo option so i can use it with my 50W Fiber but i’ve run into a problem.
The “Find my device” seems to work fine, i import the ezcad2 file successfully and create the name and work area. When i select the device, it instantly says “Framing” and down the bottom, the status says “Error Encountered - Disconnected”.
I have tried reinstalling a few different versions.
I have tried removing all device drivers and re-installing the lightburn galvo driver
I have tried disconnecting/reconnecting/rebooting both the PC and the laser
I have tried re-creating the device
I don’t know what to try next other than ask for a refund.
I have enabled debug logging, here is a snippet:
23:46:11.020 D: “LightBurn 1.4.05” “Wed Jan 24 2024”
23:46:11.071 D: Running startup sequence
23:46:11.071 D: O: “090000000000000000000000”
23:46:11.372 D: Operation timed out
23:46:11.372 D: O: “090000000000000000000000”
23:46:11.678 D: Operation timed out
23:46:11.702 D: Attemping connection…
23:46:11.785 D: Port: 38280 39065
23:46:11.785 D: Found supported device
23:46:11.785 D: Attempting port open…
23:46:11.789 D: Port open succeeded
23:46:11.789 D: Connected
23:46:12.094 D: Operation timed out
23:46:12.198 D: Running startup sequence
23:46:12.198 D: O: “090000000000000000000000”
23:46:12.502 D: Operation timed out
23:46:12.502 D: O: “090000000000000000000000”
23:46:12.806 D: Operation timed out
23:46:12.826 D: Attemping connection…
23:46:12.914 D: Port: 38280 39065
23:46:12.914 D: Found supported device
23:46:12.914 D: Attempting port open…
23:46:12.914 D: Port open succeeded
23:46:12.914 D: Connected
23:46:13.216 D: Operation timed out
23:46:13.319 D: Running startup sequence
23:46:13.319 D: O: “090000000000000000000000”
23:46:13.621 D: Operation timed out
23:46:13.621 D: O: “090000000000000000000000”
23:46:13.923 D: Operation timed out
23:46:13.944 D: Attemping connection…
23:46:14.032 D: Port: 38280 39065
23:46:14.032 D: Found supported device
23:46:14.032 D: Attempting port open…
23:46:14.032 D: Port open succeeded
23:46:14.032 D: Connected
23:46:14.334 D: Operation timed out
23:46:14.436 D: Running startup sequence
23:46:14.436 D: O: “090000000000000000000000”
23:46:14.739 D: Operation timed out
23:46:14.739 D: O: “090000000000000000000000”
23:46:15.044 D: Operation timed out
23:46:15.067 D: Attemping connection…
23:46:15.149 D: Port: 38280 39065
