Hola soy nuevo
Mi dudas si Galvo es compatible con MKS 32bit V2
Lightburn si es compatible MKS 32bit
hi i’m new
My doubts if Galvo is compatible with MKS 32bit V2
Lightburn if it supports MKS 32bit
Hola soy nuevo
hi i’m new
Gracias a todos por la ayuda que no me habéis dado ninguna
Thank you all for the help you have not given me any
La cuestión será probarlo por mí mismo comprando galvo y así podré saber si es compatible con MKS
The question will be to try it myself by buying galvo and so I can know if it is compatible with MKS
Continuing the discussion from Galvo quiero saber si es compatible MKS y GRBL:
Hola a todo el mundo otra vez bueno yo quiero saber si alguien es capaz de responderme si galvo es compatible con MKS
Hello everyone again, well I want to know if someone is able to answer me if galvo is compatible with MKS
Lightburn si es compatible con MKS pero mi duda es saber y lo es con GALVO
Lightburn is compatible with MKS but my doubt is to know and it is with GALVO
The control boards for Galvo devices are much faster than the MKS.
The driver chips for the actual galvanometers are considerably different from stepper motor drivers.
The Galvo lasers that are supported by LightBurn already have a Galvo Controller.
Galvo Lasers that are not supported by LightBurn, such as ones running Ezcad3 boards can be reverted to Ezcad2 boards and be controlled effectively.
Please accept my apology for the delays.
My Spanish is so weak it would be an insult.
If you are buying an MKS board, you have no need for LightBurn for Galvo.
If you have a Galvo laser that has an unusual control board, the MKS is not a known working upgrade path. A different control board would be required.
Muchas gracias por la respuestas aún así me quedan algunas dudas que si le parece bien comentamos en otro momento para mí hoy ya es tarde
Gracias
Por cierto tú español es perfecto gracias poel esfuerzos realizados para responder me
Yo no utilizo laser galvo yo utilizo láser casero yo tengo esto de la imagen
Esto es lo que yo tengo un láser CO2
Mi pregunta era si galvo es una extensión de lightburn para mejorar el grabado 3D de laser y si hera compatible con la controladora que yo tengo la MKS
Lightburn si es compatible con la MKS la he probado y funciona bien
Estuve mirando la opción del grabado 3D en Lightburn y no me sale instalé de nuevo Lightburn y en la última ventana marque la casilla de Galvo pero me sigue sin salir la opción de grabado 3D en una imagen PNG en las propiedades de imagen 3D no sale
La opción del grabado 3D se puede realizar con lightburn o
Lightburn + Galvo
Muchas Gracias
Un saludo
Juan
