Galvo / Rotary Question, center moved 8 cm with rotary, center is perfect without rotary
Good morning, I have a problem, after downloading the update everything worked fine, today I tried to engrave a writing with the GALVO using the ROTARY, nothing happened. The center moved 8 cm, while if I don’t use the rotary the center is perfect, did I forget some settings?
Thank you
Hi,
check your Output Center, described here:
Sounds like you accidently typed a wrong value in it and your marking area is somewhere else.
