Galvo speed seems incorrect
I’ve got a BWMTech BWM-100-F. According to the spec sheet it has a Ouya galvo head. When I do a fill on a square that’s 5" wide with the speed set to 1000mm/sec it’s clearly moving at about 125mm/sec. I can easily time this at this speed. Am I perhaps missing a setting somewhere? If I do a material test and vary the speed from 100mm/sec to 1000mm/sec I can clearly see that with each of the 10 steps of speed it is moving faster as the speed is supposed to increase. But it seems to be about 1/8 of the set speed.
Have you correctly imported the config file when you created your machine profile for the laser?
This was user error. Figured it out. Thank you.
