GCode compatibility issue with WinCNC controller
Hello,
I am trying to configure LightBurn Core 2.0.05 to generate GCode compatible with a WinCNC controller (laser diode setup).
I am not using GRBL or UCCNC firmware. The controller is WinCNC.
The issues I am encountering:
  1. LightBurn automatically injects setup blocks such as:
    G00 G17 G40 G20
    WinCNC rejects G17 and does not accept multiple G codes on the same line.
  2. When using variable laser power, LightBurn outputs:
    G1 X… S20 F…
    WinCNC rejects S parameters inside motion commands.
  3. Even when modifying Custom GCode settings, LightBurn still injects internal setup code.
My questions:
  • Is there a way to completely disable automatic setup code injection (G17, G20, etc.)?
  • Is there an officially supported GCode flavor that is closest to WinCNC?
  • Does LightBurn officially support WinCNC for laser control with variable power?
I would appreciate guidance on the correct configuration for a WinCNC-based laser machine.
Thank you.
Hi @ccprau
This isn’t a setting you’re missing.
LightBurn generates laser GCode in a fixed format (including how it handles setup and variable power), and that format can’t be fundamentally changed or turned off.
WinCNC is not a supported laser controller in LightBurn, and there isn’t a WinCNC-specific output mode or post-processor available.
