Hi Everyone,
It has been quite awhile since I have engraved on glass and now am trying again, but I simply can’t remember why I am getting a G-Code Error 9. Have tried resetting the machine settings and all, but can’t get it to work.
Thanks
Hi Everyone,
Thanks
Thank you very much. I got it figured out.
Would you happen to know why my system will NOT home or move after installing a Laser Tree K20. I have used it before and this time, nothing is happening when I start up my machine. Everything turns on, but nothing moves.
Rita
The K20 is a recently change?
Did you update the power supply also?
Check if all your plugs are well seated and inner pins in place.
Also check if you have a switch (frame underside) set to YRR.
