**how do you get the generic lay out back for you side panel all ready reset to factory settings still wrong
Window menu > Reset to default layout.
Can you please provide additional information or maybe a screen shot to help us âseeâ the issue you are trying to solve. Your profile only lists that you have a â5030â and I have no idea what that is. If you update your profile, folks can see what you are really using.
I am only talking about light burn program it was great just the way it was when I first installed it now it all messed up just want it back the way it was when I first installed it by the way this is supposed to be a picture
Alt-PrtScr will take a picture of the currently active window. You get an image that is easier to see and doesnât have all of the interference that is present in the image you uplaoded.
Here is a âQuick Tipâ video about "Arranging your Workspace that might help. Window layout can be setup in user desired ways by dragging windows around and docking where you want.
Whe
n I get the laser screen it is missing so much it doesnât look at all like your first screenshotSorry you are having difficulties with this James. You say, âThat doesnât work
I wish it didâŚâ when I just posted showing that it does. You will need to provide a more verbose description of the process and results for us to diagnose your issue. You have not said, but from the pic you posted, I can see that you are using version 9.01and is that windows10? What part of the video example does not work for you?
BTW, â20 letters reallyâ. We do this so we donât get, âbroken, help!â posts with no valuable info being shared.
that make sense. if you look at my laser panel on the right hand side of the screen you will see that it only has ready start pause stop then under that home frame frame under that devices and then my cutter where did the rest go??
I think the issue is you have âbeginner modeâ enabled, turn that off and see if that solves your problem? I did that too and did not realise that would have an effect on the cut settings. Maybe the âlayout resetâ could change that beginner mode to advanced again too?
Good catch Enno. Having âBeginner Modeâ turned on would result in what is being displayed. Configuring this option can be found in the âSettingsâ window.
got fooled myself and did not understand
@Jchendy - Can you please confirm. Did this resolve your issue?
thank you so much you where right again love your program and thanks!!!
could not answer before 22 hr sorry
