Gentry trackjing
Right side of gentry not tracking with left side
If it’s more than a statement and you’re asking for advice, I’ll look into what’s wrong.
Depending on the machine, it may be a lack of lubrication or there is dust and dirt or mechanical wear of moving parts…
Unplug the machine and examine the mechanical system.
I had a similar problem with my first diode laser. For me it turned out to be the coupler that connected the Y axis stepper motor to the cross shaft. After I tightened it, the problem went away. That might be something you’d want to check, if your machine has the same type of coupling.
My guess, Christmas present and adjustments haven’t been made.
