good day
can someone tell me what i did wrong and how to get it right
thanks in advance
greetings Ronald
It’s indicating that your “Life after fill” speed settings is equal or faster than the speed setting for the fill itself. If you don’t want to see the warning then reduce the speed in “Line after fill” tab of the cut settings to be lower than the fill speed for that layer.
thanks for the reply
where do i change this
Fill setting speed - > main cut settings for layer
“Line after fill” speed → “Line after fill” tab under main cut settings for layer
bedankt
thank you
