My neje 2S max is totally going nuts.
I have been using the laser for a month and everything was perfect, but today, the day i bought the licenses, between some cuts, something happen…
Feels like the machine is drunk.
Let me explain you.
When i click home, it goes to top left corner of the workspace (good) but if i check my position place it shows x810.00 Y 920 (my working size it’s set to width 810 height 460 on the device settings)
How can i fix it?
i tried to move manually my laser to the right bottom corner and move it with the arrows so i can bring it to x0 y0, but after that i click on set origin, it goes back to the x810 y920.
I have been fighting for hours and no idea what to do.
You have a workspace offset enabled. Did you use LaserGRBL or some other software and ‘Set origin’ in it? You can clear that by typing this in the console:
LightBurn never issues commands that will change this (you have to do this either through the console, or a macro). The only way this could happen is if you homed the machine and the home location was strange, like rear-right instead of front-left.
