Just want to report an update error. Did not get update notification when starting up Lightburn & received TLS initialization error when I asked lightburn to check for updates.
I’m having the same issue. No notification, and update checking either hangs or I get the TLS error. Need this rectified as I need lightburn working correctly to get orders out, and it is being pretty janky…
I have just downloaded directly from Lightburn.
Before installing, my laptop had to update the visual c++ redistributable downloads.
The Lightburn update then installed, and on checking updates I got the you are up-to-date message, whereas before it would hang or I got the TLS issue.
This is a known issue for the initial 1.5.01 release that was later corrected. Manually downloading the latest version is the correct course of action.
Why do they keep the same version ID when they make these updates???
If you make a change to the install please change the version number.
Adam discusses that here. I believe I’ve seen Oz also cover this some time ago. Bottom line, it’s not all that straightforward and there are practical reasons for this.
