im getting an error saying layer 5 raster has line speed that is the same speed that is the same or faster then the fill speed . i get this from down loading as 5 layer file . what can i do to fix this
Change one of those settings? Not trying to be cheeky with this response, but you can, and should, adjust these settings to best match your laser, the type of cutting and material you have chosen. I would not recommend using someone else’s settings, without checking them for myself first.
thank you for the response just learning trying to figure things out
Under the ‘Laser Tools’ menu, look for ‘Material Test’. This has been recently added, which lets you generate and run test grids with varying settings.
Here is the test that is generated,
