Can someone help?
Last year I built a DIY laser diode cutter for balsa using Grbl 1.1 and Lightburn. It took a lot of time, lots of challenges, but I got there and it worked; but not well. My mechanical design was poor, it relied too much on MDF. As a result the gantry was not smooth and the Z axis (bed) kept going unlevel. Spurred on by minor success I embarked on a redesign. Now it uses aluminium extrusion, the gantry just glides and the table is and remains level.
I’ve just got to the exciting part of cutting some balsa, there is a problem and I need your help. Now the gantry is smooth, I changed the DRV8825 to quarter steps on the x axis, to make the machine quieter. It was no surprise that the x steps had to be changed. I got a 2 foot rule, homed the machine bottom left and then marked on the extrusion 610mm. I then put into the console G00 X610 and it fell short by about half. No surprise. Went into machine settings, ‘calibrate access’, put in 610mm for what I requested to move and then recorded the actual movement. It suggested a value which was applied. Went through this routine a couple more times until the actual movement was exactly 610mm. Result.
I then drew a circle in Lightburn of 10mm * 10mm. Set the table height, closed the lid and pressed Start. It buzzed for a few seconds and then stopped.
Rather than a circle, I got an oval. The height of the oval is 10mm and the length is 20mm. X is moving twice as far as intended. Put in G00 X610 and it moves 610mm from the homed position, perfect.
Checked the G Code for the circle job and Lightburn is asking for X and Y to move 10 mm from where it switches on the laser. Just as it should.
Done all the obvious things like rebooting and checking the setting were saved; they were.
I’ve done some reading and seen some folks have had the same issue having switched rotary on. I’ve not touched the rotary, was not even aware of its existence and have confirmed it is disabled.
So close yet so far. I’m sure it will be something simple. Can someone turn on the light for me?
Thanks in advance
Howard
