erro 20 - comando de codigo g nao compativel ou invalido encontrado no bloco linha ou perto da linha 3.
o que pode ser
Bloco de Citação
error 20 - unsupported or invalid g-code command found at or near line block 3.
What can it be?
o que pode ser
Bloco de Citação
What can it be?
New engravers allow an image handling tool called GCode Clustering.
I believe that the Zbaitu engraver you have, comes without this feature.
Click Edit, click Device Settings, turn off GCode Clustering, click OK at the bottom of the window to make the change to the settings.
Please let us know if this is the solution. ![]()
