I am running Millmage V8.02 on a FocAlien 4040 XE machine. The homing function and move buttons all cause the machine head to move in the proper direction, but when using the Go To buttons, the head moves in the opposite direction to what is expected. Please help!
PS: I also use Lightburn with a laser head attached on this machine and all homing and move functions work correctly.
Check your Zero Point is correct.
If your machine is traveling in the opposite direction as expected I would try changing your Zero Point Configuration to the opposite corner.
