Goes through motion won't cut
Hi Mike, I’m trying to do a test pattern and nothing is working except the max power. What am I doing wrong? I’m trying to figure out what settings to use to get my fill lines right but it works on some places and other places it doesn’t. How do I get a test pattern to work for everything? thanks
1600 speed at 50% is working but if i want it lighter do i speed it up or power down?
Both options will reduce the amount of photonic energy delivered over time.
No such thing. Different materials “burn” at different rates. In fact, the same material ordered later can have different charastics. Even so, the Material Test is only intended to give you a range of settings. From there you will be making small adjustments to get the correct settings for that particular project.
