I’ve used Lightburn long ago for some other projects (making graphene, oddly enough). I just aquired my first industrial laser and so I wanted to consider using it rather than the vendor software.
Its a chinese laser (yes, I know). It seems to be using Lasersoft software to generate a .las file, which is supposedly machine format.
The controller is not one listed at the laserboys golden site. Any one know anything about a *.las file format; what are my chances at using different software such as Lightburn, or less likely if newer versions of Lasersoft can be used with existing machine/dongle/…
This doesn’t seem likely, in that I do have the ability to specify power as % and speed in mm/sec?
I can read the servos etc, but I can’t get to the controller without taking the pedestal apart.
Without knowing what you’ve bought, you are unlikely to get any response to your question.
If you don’t know what you have, having bought it and with the machine in front of you, how do you expect us to?
Nothing you’ve mentioned turns up on searches. You say your machine is using ‘lasersoft’, but there’s little information about a laser control app called ‘lasersoft’
There is one called ‘laser soft’ which is the one I referred to.
Better information from you will result in better responses
