Grabar acero inox - Engraving stainless steel
como puedo grabar acero inox con sculpfun s9
How can I engrave stainless steel with Sculpfun S9?
Slowly, with maximum power. I would think 10w would be the least power laser that would work. If it is polished SS, tilt it slightly so the beam does not reflect back up into the laser.
hola, he probado asi y sigue sin grabar nada. Hay otra solucion
What is the output power of your laser?
What speed, interval, and power are you using?
Just found this on the Facebook Sculpfun forum. Not surevwhat the “.6” is, it might be the interval value.
Stainless steel wine bottle openers done with S9 10w module
450mm/m
90 power
.6
2 passes air on
Painted with black sharpie
