Gravering och klipp inställningar akryl 3mm xtool P2
behöver hjälp med gravering och klipp inställningar akryl 3mm xtool P2 någon som parametrar för detta?
It is possible that there are other users who have the same machine as you and want to share their acrylic settings, but… The best thing for you would be to find some leftover acrylic and experiment to find the exact values ​​that suit your machine. Use the test templates that are part of lightburn and you are good to go.
hej jag har inte tid att prova mig fram. jag har produktion av medaljer med gcc laserspirit maskiner och använder flexidesigner saicloud för det.
jag har nu köpt 2 st xtool p2 och p2s och då är det helt annorlunda i lightburn. aldrig jobbat i det programmet innan.
Here’s where your laser manufacturer has provided settings for your machine:
Here are the settings for 3mm White Translucent Glossy Acrylic:
Upon creating the device profile for your laser in LgihtBurn, did you import xtool’s settings as described in their documentation?
I recommend migrating your settings to ensure each computer is using the same:
Although @JessN has given you some important information, I still stand by what I wrote before.
If you are so busy and do not have the material to test and fine-tune your settings, you are unlikely to achieve good production results and will probably throw away a lot of material anyway. But, of course, this is just my personal opinion, based on my own experience and production with my laser machines.
