Pozdrav,
Zanima me graviranje po metalima. Koristim diodni laser od 80w(GRBL).
Da li ima odredjena visina i snaga koja se mora podesiti prilikom graviranja.
Unaprijed hvala na odgovoru.
Greeting,
I’m interested in metal engraving. I use an 80w diode laser (GRBL).
Is there a certain height and power that must be adjusted when engraving.
Thank you in advance for your reply.
If the visible light from your diode laser is reflecting off the metal, it’s not being absorbed. Paint or ceramic material may allow enough heat to anneal and mark metal but you will find engraving metal with a diode laser nearly impossible.
