Hello
I burn a photo on Rdworks as I prepared it before but when I use lightburn image will be burned according to 5 writings as threshold gray shade ect … and I don’t want any treatment so which option I must choose
thank you
In LightBurn, set the ‘Pass-Through’ switch in the image layer. It will be simple threshold (just black / white with no shading) and every dot (pixel) in the image will be sent to the laser exactly as it is. You won’t have control over DPI or be able to rotate it other than 90 degree increments, because those would require resampling the image, which pass-through disables.
ok merci👍
ok j’avais pas vu cette option
merci
