Gravure sur feuille de cannelier avec sculpfun ICE 10w
Bonjour à toute la communauté, je souhaite faire des gravures sur des feuilles d’arbre de cannelier, avec un petit laser 10w sculpfun ice pro, Avez vous déjà fait ce genre de gravure? Avez vous un point de départ pour le paramétrage du laser? vitesse et puissance afin de faire des test et ne pas gaspiller trop de feuilles. D’avance merci pour vos suggestions
Hello everyone in the community. I’d like to engrave cinnamon tree leaves using a small 10W Sculpfun iCube Pro laser. Have any of you tried this kind of engraving before? Could you suggest some starting settings—speed and power—so I can run tests without wasting too many leaves? Thanks in advance for your suggestions.
I have not seen any mention of this in any posting. I have seen where some foods were attempted, but no leaves.
Instead ot wasting a lot of leaves, try doing multiple line engravings (squares or circles) on one leaf to get an idea of what power and speed setings work. If a leaf is green, then [1] it may need more power than expected (compared to wood) and [2] the leaves contain moisture that will impact the results.
I have a 10w diode, but I have no idea what will work. I suggest start out using 1000mm/m, 15% power, and 1 pass. You also did not say if it was a line engraving or an image. If an image, I would use one of the dot type modes, like Newsprint or Halftone.
You are the pioneer here, so test, test, test, and then start a new Thread. I did this for engraving stones ( Fried some rocks! ) and the activity went crazy! Be adventureous, start a new fad. :grin:
Merci pour c’est infos, je vais faire des test et je mettrais ça sur le forum, “quelques fois il est bon de ne pas chercher réinventer la roue”:ok_hand:
you say laser , but you have , have picked mill mage which is cnc to ask question , change your category to lightburn where you will get more assistance , :slight_smile:
ok merci je n’avais pas fait attention…
Ideally, to avoid wasting too many leaf, you should get information from someone with a similar machine, or at least one with similar power, who can share their experience. This will serve as an initial guide. However, testing with your own machine will always be necessary to find the most suitable settings.
Idéalement, pour éviter de gaspiller trop de feuilles, il serait préférable de se renseigner auprès d’une personne possédant une machine similaire, ou du moins d’une puissance comparable, qui pourrait partager son expérience. Cela constituera un premier guide. Toutefois, il sera toujours nécessaire de faire des essais avec votre propre machine afin de trouver les réglages les plus adaptés.
Tout a fait d’accord avec vous, mais je cherche quelqu’un qui pourrait me donner un point de départ afin de faire mes propre calculs et grilles de test
What I can say in advance, because I’ve never engraved tree leaves, is that, being an organic material, the power setting will be low.
Ce que je peux dire d’avance, n’ayant jamais gravé de feuilles d’arbres, c’est que, s’agissant d’une matière organique, la puissance sera faible.
This is a double posting, which has another response. Please merge that into this one. Thanks!
Another thread with the same question…
@Soina06 Please do not post the same issue multiple times in more than one post. This double-posting causes more work than necessary. Thank you. :slight_smile:
