I definitely think the result (your last picture) is very successful, especially since the material is slate!
I don’t know does ink have a minimum drying temperature (the workshop is a comfortable temp) or has the first lasering changed the material surface, but yesterday’s application of ink had not dried by this time…so I hit it with the heat gun for a minute or two and pressed Start!
Also thought to reduce power settings by two-thirds and increased speed ~25%.
I have to ask what kind of machine where these greyscale images done on, as far as drive mechanism. Where these done on a belt drive or linear rail. I cannot get a greyscale to come out without a curtain effect unless I lower the speed so low it would take hours to do a small image. I am running a belt drive. I am thinking about converting my X axis to linear drive if that will solve the problem.
D
Can you post a pic of your outcome on slate and a screenshot of your settings and the image adjust screen with settings.
I’ve been using Jarvis for the current image and the last greyscale I did was Jay’s Franken car..and previous to that.
I’m using the ‘Snapmaker-Ray’ machine and it’s belt drive with linear-rail. 20w & 2wIR1064nm.
I got that re-run done bernd, but after the window finished I stopped and re-adjusted power values back up as it was way too dark. I couldn’t do the second run because I had raised the power back up too far…forgetting about the second scan with alternative angle.
This one is a lot moodier, the window is good…looks a lot more real with just a hint of slate/blotchyness showing. The face is a touch darker also, with good completion but the headscarf is letting it all down. The detail/fabric look is harder to appreciate and the darker areas just look flat, …that might change if the ink fully dries out and lightens up a bit or maybe it requires a larger Newsprint pattern so the bright lines are more pronounced, also a halo on the outer edge of the headscarf.
A bit dull and a bit late to be taking pics but there it is anyway.
This is white tile that seems the worst for vertical banding. This is done on gradient from black to white. The banding is most noticeable at higher speeds and lower power. Have tried numerous settings, dpi, min max power, speeds from 1800mm/m to 1000mm/m, loosening belt, tightening belt. Only thing that improves it is low speed and higher power, which then doesn’t gradiant into white. The second upside-down image is around 1000mm/m banding is minimal and shading is good, but those speeds would take forever to engrave. I’m thinking greyscale is not practical on a belt driven machine assuming this banding is caused by tooth and belt timing.
D
In the top image, is the laser actually removing material to a depth…looking at line 19 especially but others also..maybe it’s just the photo appearance.
The power/speed (no speed visible) test shows three usable tones like Off white, mid grey and black but this does not matter for greyscale,…so just don’t burn harder than needed for black or less than required for off-white, Zero power(min power) is only used if there is white in the image.
There is no way to judge the Greyscale outcome other than to say that the good black rectangles (Power 48% to 52%) show the max power needed in the settings and speed required, and if there are white areas in the image you want to engrave they require zero (min) power in the settings for Greyscale mode.
I would say, set the speed to what you would like it to be with max/min power set according to the test grid. Burn your image, If blacks are not good slow ir down gradually until they are just right.
If you don’t absolutely need this in greyscale, use a dither and set your speed to what you want it to be and keep it there but keep raising the power until the dithered image is good. If power needed is too high, then reduce the speed gradually until image is good.
The banding is a mystery to me and if your images work OK on other materials I would question the tile itself before over adjusting the belts. Anyway, if the belts were loose/tight that would not effect the power output by the module, it would also show in the other tests such as the nice black rectangles.
19 was I forgot to move test down and burned twice. It’s not speed and power settings I am having problems with but the banding that shows up in the images. I guess I will have to stick with a dithered image and forget greyscale.
Are you coating the tile in Tio2 solution or just burning the bare tile.
You have wide dark bands and thinner bright bands…how wide would you estimate are the thin brighter bands.
What power% is it using to get the banding and what power burns consistent black in the greyscale gradient.
The banding is very consistent so loose or overnight belts may not be the issue. Your profile says custom built…are the belts/teeth larger than usual. What dot size and is the dot (tall and thin) or (short and wide).
Have you had/do you get this issue with other jobs or materials.
The software will output the greyscale power levels no mater what, so if it was mechanical the issues would show up but the gradient would be dark to bright (or the reverse) from start to finish regardless.
I think it’s a material reaction to heat and the surface reacts consistently at some power/speed levels and not at others, making your method not-optimal for greyscale.
I am not surprised that there is banding. Trying to get 256 levels of gray to show up in a smooth band is difficult to work on any material. In printing we talk about 0-100% gray, and that is hard to do with ink on paper. That is why halftone was created. The optimal halftone screen was 200 line screen. In a black and white image that worked well, but doing color was a problem because of having to print each color at a different angle which caused a moray pattern. Then the computer got involved and stocastic (dithered) was introduced for high end color printing. The moray pattern problem disappeared.
When I do grayscale images, I’m happy to get 64 levels of gray on a piece of wood. You have to remember every material or even individual pieces will react differently, and when you introduce an applied coating on top of that you end results will almost always vary by as much as 10%±.
I went through 24 sheets front and back just to get to where I could a baseline setting, and that is just on basswood plywood. I don’t want to go through that on Baltic birch or maple, etc..
I can see where any one of the dithered patterns work. Each one of the patterns generat lighter or darker patterns. Atkinson works better in lighter images, Jarvis works better in dark images. Each one has their pluses and minuses.
That’s one of the reasons for experimenting with depth maps. It isn’t practical to do really deep engraving, but grayscale is the only way you can get variable power output. The trick is to figure out how you can control it.
Wood is more forgiving than tile or slate or stainless. They all react differently.
I have fun pushing software into doing things it is not supposed to be able to do. Lightburn works in a black and white world that allows you to do minimal photographic work by using dithering.
We are pushing software and different mediums beyond what LB intentions are.
Nice writeup Jay
I’m not expecting that any mode will automatically give a good image but every little helps!
So can we infer that Atkinson would be more useful to lasering a bride in a white dress and Jarvis would be more useful to laser the groom in a dark suit.
Is it not about the arrangement of dots but more about the ratio of white to black per square millimeter…for example.
Dithering gives me little to no banding, and I have been using atkinson on white tiles sprayed with gloss white paint. I tried halftone and it gave the best transition from dark to light. But ya there are tradeoffs on every mode and greyscale is the most challenging and probably not doable on tile or slate.
I think mostly, Dither is the best choice as greyscale images can be a bit flat even at their best but greyscale is fine for Ai generated images that are designed for lasering from the get go, as opposed to ordinary images that are designed for screen and paper. I went and watched a video on how dither was developed for graphic imaging and then brought some images into Ditheristra which has maybe 30 different dither types, most seem pretty same same. I reckon LB has all that’s needed.
I haven’t tried tile burning yet, must give it a go sometime soon. Glad it turned out your machine is ok.
Yes, you are correct. At least that is my finding. You can see how it affects an image in the adjust image tool. Zoom in on the image and apply each of the dither options and you can see what the differences are. The trick is to get a good balance in grayscale mode, the pick what dither option you want, and the adjust the image a little bit more towards the highlights or shadows.
Fine tuning the image here is what will give you the best output.
It’s hard not to obey what the eyes perceive on the screen in terms of crushed shadow’s and highlights and I constantly want to adjust to what seems correct on the screen.
I get your point about setting it just a bit brighter than appears correct but do you think that works out on the material most of the time or just enough to make it a general rule.
It is at that precise point I would very much consider handing it over to Ai to build an image designed for laser engraving. At 3.5 to 5.5 hours to complete a job I’d feel the need to be somewhat certain, especially if it were a commissioned piece.
I tend to agree with you (a lot). When it gets to crunch time, you have to pull out all stops and just get it done with the best quality you do.
There is a time for experimentation, and a time to make money.
That’s why I am glad that I a retired, and don’t care how long or experimenting it takes. As long as I can pass along my results I am happy. Some of the results work and some don’t, but I have fun.
I am truly amazed how the thread has grown. If someone would have told me it would grow like it has I wouldn’t have believed them. I hope it continues.
I’m afraid if nobody contributes anymore, this thread will die.
If you find it interesting the please contribute.
338 postings. Even if there are no more, it will not die. I will just go dormant. A Forum search will find it.
How many people can be expected to read 338 postings in one thread? ![]()
It’s funny how this thread has progressed. I started with just explaining what grayscale is. I come from a printing on paper background, there are a lot of similarities between paper and lasers. We used to calibrated our monitors to get a visible image as close to the printed image (WYSIWYG). That concept was flawed because on printing on various types of paper. Like wood, tile, and other types of material, everything changes, then you throw in the different lasers, humidity, etc. you can drive yourself insane. My hobby, though it may sound strange is to push something as far as I can to do things it isn’t designed to do, just to see if I can do it. In this case push Lightburn into generating good quality variable power (grayscale offers that) images. Dithering is absolutely will give the best outcome, but you need to give it the best possible image before you apply dithering to it. That why you need to understand grayscale. I would also explore a halftone setting if dithering isn’t giving wou what you want, that works well on paper so why not other materials.
If we step back and look at an image. Take a photo with a film camera. The person was given different types of film for contrast, lighting, portraits, etc. each one excelled in what it could do. The person develops and prints the image. Different types of paper gives different results. Then an experienced person like Ansel Adam’s comes along and knows how to modify an image at the enlarger and over or under exposes parts of the image (dodging). We do similar things with a digital image, professionals do that in specialty software now. Things have come full circle.
A laser is only a small point of super focused light, what we do with it is what makes an average image or an outstanding image. I can make a good acceptable image, but someone with a better understanding of photography and something like Photoshop will create an outstanding image.
I am fortunate that I am not using the laser to make money, but to explore a different hobby (I have had many). That give me a lot of time to explore, and pass along the knowledge that I find (some good, some not so good).
My motto.
GIVEN ENOUGH TIME AND BEER, YOU CAN DO ANYTHING!
I hope everyone that everyone that reads through all of the information learns something.
This isn’t the end, it’s just the beginning.
More to come.
