I genuinely think this is a settings issue - You keep saying “can’t engrave images” with no further description of what it is or isn’t doing, which isn’t helpful. Make a small test image, click “Save GCode” and post the generated file here. There’s a chance I’ll spot something there.
Why does my version working with ruida not have the overscan option?
Ruida handles overscan in hardware. And for questions unrelated to the original post it’s generally preferable to create a new post with your question.
today I started my pc and tried to engrave and it worked. no idea why.
other question: i cant change the min power%. how can i solve this? its bloked, thanks.
You can only change Min Power if you are using grayscale, so you likely have it set to use a dither method.
