The laser is not active immediately when you stop and start the lightburn software. After stopping and starting the software, the laser is active after 2-3 seconds. please help me.
Which version of GRBL are you running?
hi dear friend
grbl1.1f
In that case, as long as it is in “Laser Mode” by setting $32=1 in the console, it should resume with the laser back on. I will have a look in the code.
$32=1 actif.
please look video . you see
dear firend . can you look in the code.
The software does not work properly. The error in the video is related to lightburn.
Yes, I am aware. Repeating it will not make the fix come faster, sorry.
config.h change
//#define DISABLE_LASER_DURING_HOLD // Default enabled. Comment to disable.
ok . now no problem
