I have GRBL 3018 Pro. I’ve added limit switches to all six points of contact. I’ve set $23=0, and I am ok with home being 0, 0 in the upper right corner. I’ve set my origin to the upper right corner (experimented with all four locations.) All that is fine. The problem comes to movement of the laser, in that it is inverted. With the laser in the upper right corner, I can only use the up and right commands otherwise I get endstop errors. When clicking up, the laser moves down and the laser position symbol goes up. When clicking right, the laser moves left and the laser position symbol goes right. (up and right off of the working grid)
If I change the point of origin to bottom left. The direction buttons match the movement of the laser, but the position indicator now goes down and left off of the working grid.
$0=10
$1=25
$2=0
$3=2
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=0
$24=25.000
$25=500.000
$26=25
$27=5.000
$30=1000
$31=0
$32=1
$100=800.000
$101=800.000
$102=800.000
$110=1000.000
$111=1000.000
$112=600.000
$120=30.000
$121=30.000
$122=30.000
$130=285.000
$131=177.000
$132=41.000
