I’m getting this code trying to make a grid on spoil board. Laser hard stop at top of X & Y axis.
Grbl 1.1h [‘$’ for help]
That’s not an error code.
What is the problem your having?
I have a line set to 400X400, It will frame with no problem., but when I run the path I get a hard stop at the back right of the path. I kept the line centered in the grid and kept reducing the size of the path until i go t 310mm and it ran that pass with no problem.
Define a hard stop. Software or mechanical stop?
The laser travels all the way to the end of the rail and hits the limit switch with a small thud and stops right there.In playing around to see if the 410X410 was correct, I can send the laser to Y=410 X=410 with no problems from the Move Tab Could it be anything with the Laser offset that I has in the settings?
