Hello,
I recently became interested in Diode Lasers. I’ve used a CO2 for several years along with Lightburn. I’m having trouble with my machine not homing. I have Windows 10 and Lightburn grbl.
I have working limit switches in the lower left corner. I’m using an AnnoyTools Laser board.
I sometimes get the following error message: “Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.”
Here are some screenshots of the Machine Settings:
I assume the machine starts moving toward the home switches when you start it up or initiate a homing cycle. If not, flip the X and Y Homing direction invert switches as needed.
Assuming the X and Y Max travel values are correct, then the Homing Pulloff is excessive. Reduce it to about 3 mm and verify the switch levers completely relax after homing.
An initial homing seek speed of 3500 mm/min seems far too high for comfort. Reduce that to 600 mm/min; you can increase by factors of 2 after everything works correctly.
Thank you Ed for taking the time and responding to my issue.
This morning I implemented your suggestions without any difference in how the machine responds.
I’ve included below some screen shots and the following error message in the Console window:
ALARM:9
ALARM:9
Some behavior notes:
If I activate “Auto home on Startup” from the Device settings menu, the machine doesn’t boot up and find the controller.
If I start the machine without the Auto-home activated, the machine will connect up to Lightburn and take wherever the Laser head is to be the 00 coordinate and if I move the laser head and then press “Go to Origin” the laser head moves to that starting position.
If I press the home button, the machine hangs up and doesn’t move at all with the green progress bar as seen in the first screenshot above.
So the machine does not seek the limit switches. I have tried inverting the homing direction with no change.
In general, the machine accurately cuts complex shapes.
Thank you in advance, Mark
It must home on it’s own… when it powers up the head should move toward the home switches… does it? The only acceptable answer here is either yes or no…
If it doesn’t, then we need to look into how the controller is configured or wired…
If it does then we need to check that the home switches are being read by the controller…
Jack,
I deleted Lightburn and reinstalled everything. Switched the Home to the rear left and incorporated the suggestions from above. Still no luck. I can use the machine as is, but it’s nice to have the Homing feature. I will let this topic sit for awhile in case anyone has brainstorm. Thank you for your help. Mark
check “Auto home on startup” under the Device Settings, the machine hangs up
Let’s start from the beginning again.
How do you know the limit switches are working? Specifically, have you verified the controller’s input pin goes low when you poke the switch with a finger?
You have Hard Limits turned on, which requires switches on both ends of all the axes:
If that’s not the setup, then turn Hard Limits off.
Turn off LightBurn’s Auto Home, but leave GRBL’s Homing Cycle enabled.
Turn off the laser, drag the laser head to the middle of the platform, and turn the laser on. The laser should then connect to LightBurn, but should not home or move or do anything else.
In LightBurn’s Console window, type $H and whack Enter. The machine should trundle toward the home switches at a reasonable pace, bump them, back off, bump again, back off, and stop moving.
Don’t try doing anything with LightBurn.
Does the laser just sit there after you turn it on?
Copy the output in the Console window and paste it here, so we can get a look at the initial startup status.
Ed,
I did as you requested. Both Hard and Soft Limits are set to Off. Started up the machine and no movement.
Here’s the output in the Console window:
Waiting for connection…
Ed,
I just did as you suggest. There was no movement of the laser head. The machine hung up for about 3 minutes and then the following appeared in the console window below the $H (I’ve included the preceding console info, too) :
Grbl 1.1f [‘$’ for help]
ok
Monport
[VER:1.1f.20221206:]
[OPT:VMZHL,35,254]
Target buffer size found
ok
$H
ALARM:9
No, the firmware of the control board has already been set. You
can connect the Z-axis limit and simulate Z-axis homing before
you want both axes to go home, shorting it twice. After that X.Y
will return to home.
By ANNOYTOOLS-us Seller on October 11, 2022
Although you said it was “an AnnoyTools Laser board”, it’s apparently hardcoded as a three-axis (or four-axis) CNC controller, like all the others in the Annoy Tools Amazon storefront.
So it’s trying to home the Z axis you don’t have installed, failing, and that’s the end of the story.
It may be possible to modify the firmware to disable the Z axis homing, but that’s challenging without the original source. Even though all the desktop lasers use GRBL, the manufacturers seem remarkably reluctant to comply with the license terms requiring them to make the source code available.
I’d be sorely tempted to install a tiny stepper motor with a cam on the Z axis. The Z-axis homing cycle would rotate the cam, trip a homing switch, and the firmware would be none the wiser.
I went through the same issue about 2 weeks ago when I switched to the Annoy board to drive a 10W diode I recently upgraded to. I ended up using a spare micro switch as the Z limit switch. I guess Annoy lives up to their name as they are very annoying selling a 3 axis board for laser use when most low cost diode lasers do not have a driven z axis. The firmware can be upgraded only by using a dongle that is almost as expensive as the board. It requires familiarity with arduino programming as well. I will probably end up using a spare motor to “rig” a fake Z axis so I do not have to manually use the switch every time I home the machine.
