i’m setting up a stream deck to control things in lightburn, and one of the main things i want is to be able to move the laser head around using the hotkeys for the jog commands (num pad arrow keys)
But an issue i’m having is every time i start lightburn the ‘Speed’ box is at 0.0mm/s, so when i click one of the jog buttons it gives and error about not having a speed set.
i can grab the mouse and select the speed box, then enter a speed (usually 100mm/s) and for the rest of the time lightburn is open it works,
But when i close lightburn and reopen it, that speed box is back to 0.0.
i don’t recall it doing this in an earlier version, i’ve tried ticking and unticking the ‘Save state of move / rotate / scale switches’ and that makes no difference… but that may not be for saving the speed to jog the head at anyway.
I always have the ‘continuous jog’ button on, and i’;ve tried with it off as well, same thing, it does not seem to be remembering the jog speed i set before i shut light burn down.
is this something i’m doing wrong? and if so any ideas how i fix it.
