GRBL look ahead not working
I just built myself a little laser engraver to play with. I used whatever I had under hand, so ended up with GRBL on an Uno and a CNC shield left from a project from years ago, currently using the trial on Lightburn.
Now to the problem: when scanning, the G-code looks fine, a single line looks like this (incremental movement):
G1 X-1.25
G1 X-3.2S600
G1 X-13S0
G1 X-2.4S600
G1 X-0.7S0
G1 X-1.1S600
G1 X-1.25S0
G1 X-0.5Y0.1
Given this G-code I would expect one constant speed movement with the laser flickering, but I can see and hear accelerations from the motors. Laser mode is enabled.
I know GRBL is no longer being updated, but I was under the impression this shouldn’t be a problem. Any advice would be appreciated.
I would say your acceleration settings are low then.
Might be, but why is there acceleration in the first place? The machine shouldn’t attempt to stop.
For the sake of anyone who might be looking at this in the future:
The problem was I was running the laser at 5000 mm/min, and apparently emptying the buffer. Reducing the feed to 2500 mm/min solved the problem and faster work will probably require a better controller board.
